’91 3B Upgrade
  • Corey
    Banned
    • Sep 2003
    • 2793
    Originally posted by S2_Dave
    It started life as an 034 downpipe, but it's since had fabrication work arranged by Corey.
    Only the flexi remained from the 034 item, everything else is by us and is a true 3" downpipe.
    Clutch was from us also.
    Corey
    01636 822288
    • S2_Dave
      • Aug 2005
      • 456
      Originally posted by urquattro-island
      hello do you have the nrs for this clutch and what power is it rated for??
      I don't have the p/n, but I think it's this one. Rated to 520Nm. You can have different discs, which will handle more, but they won't be as smooth. Are you sticking with the ARV 'box for your stroker? The reason I went for this clutch is that I didn't mind if it slipped a little to help protect the gearbox and it could be sourced from within Europe (delivered in around a week). I've driven it a little with this clutch and a 3B flywheel and it's a much smoother setup than I had before, but that's probably more down to the flywheel having a bit more mass now. The pedal feels a tiny bit stiffer than with a SPEC3, but it didn't take long to get used to it. It hasn't slipped yet, but three things should be noted:
      1. I didn't do any hard launches.
      2. I didn't drive it much before I popped a hole through a Samco hose at 2.0bar.
      3. Boost didn't come in very agressively because of wastegate creep.
      I'll keep you updated if you're interested.
      David
      '91 3B S2 Coupe
      • S2_Dave
        • Aug 2005
        • 456
        God it takes me ages to write replies - this wasn't here when I started and it's almost an hour ago . In my defence, I should be working.
        David
        '91 3B S2 Coupe
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          #94
          You have the original sport quattro exhaust manifold with the gt 3071 , what kind of flange has your turbo or ex-manifold??? T3 or KKK?
          • S2_Dave
            • Aug 2005
            • 456
            Turbo has a T3 flange and it has been adapted to fit the SQ manifold.
            David
            '91 3B S2 Coupe
            • urquattro-island
              • Mar 2006
              • 1915
              • Home: Norway Current: Iceland
              #96
              yup
              Yes please do, i think i will need to change the box for the stroker, but will use it until it brakes.
              japanischer industriabfall nein danke!!
              www.rackeltrim.se Icelandic Division
              • S2_Dave
                • Aug 2005
                • 456
                Anti-surge housing has arrived.
                David
                '91 3B S2 Coupe
                  Dave where did you buy the housing from?
                  • S2_Dave
                    • Aug 2005
                    • 456
                    Corey sourced it from 034, but it took a long time to arrive. Once fitted it increased lag significantly (not what I was expecting) so, AFAIK, it's sitting on a shelf. With that news you might not be interested anymore, but if you are I can enquire for you to save you the wait I had? Hopefully I'll be up there soon.
                    David
                    '91 3B S2 Coupe
                      I know it increases lag hehe that's why I've been looking at 3" covers for the 3076r instead of the same standard antisurge covering.
                      Just wondering where it was sourced, if it was from 034 then it's most likely ATP turbos, do you know the price by any chance?
                      • S2_Dave
                        • Aug 2005
                        • 456
                        I wasn't paying for it, so I don't know what the price would have been. What's a 3" cover? I now have a milled lump of aluminium (about 100mm) that goes from 4" at the filter tapering down to the 3" inlet. Is that it? I don't have pictures to illustrate fully.
                        Before
                        With anti-surge
                        Now
                        David
                        '91 3B S2 Coupe
                        • S2_Dave
                          • Aug 2005
                          • 456
                          Some other recent shots:
                          Summer wheels
                          Quieter silencer
                          James' fuel line kit
                          David
                          '91 3B S2 Coupe
                            Loving the airbox, very nice solution in carbon, if you get anymore pics of that I'll be interested to see it.
                            By 3" cover I mean 3" inlet compressor housing, the Garretts T04 housing are interchangeable, It was so I could keep the RS2 airbox but I may abandon it
                            Is it me or is there a nut missing for the wastegate cap?
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Fuel lines and manifold look great Dave
                              Chef
                                Just noticed it's an SQ manifold! Where did you buy that?
                                I thought Aronmatic2 had bought ever last one in existence .
